Not able to hit cycle lock
Posted: Mon Apr 08, 2019 2:36 pm
Hi everyone,
I need a big help. I am part of a formula sae team. We run a Yamaha Phazer 2007 engine(2 cylinder) with high compression pistons and E85. We are using M150 ecu with the GPRP package. The team has ran the engine well on our dyno set up. The engine hits cycle lock quick and starts up fine.
We have installed the engine on the car but upon trying to start the engine, it does not fire. I have used the ref sync capture to sort out the rising and falling edge of the Speed pin and sync pin, however I am not able to hit cycle lock.
Point to note is, we ran 24V just to the starter motor on our dyno set up. However, on the car it is being supplied with 12V.
I have attached the package and logged data related. It would be of great help if someone could point the direction I should be heading towards.
