Layout Editor
Sun Apr 07, 2019 8:18 pm
by rayhall
Is there a wennar on changing, saving or importing the layout in the software.
I had some of my layout disappear. It was the knock sheet it was nicely setup with everything needed including a time chart. I pressed F6 to make one of the windows bigger and pressing it again did noting. Could not get back to the original layout. Why would F6 not make a window smaller.
Ray,
Re: Layout Editor
Sun Apr 07, 2019 11:13 pm
by karel021
I normally make my own workbook and then copy all the worksheets to that from the package workbook
then you can export the hole workbook and have it saved.
Re: Layout Editor
Mon Apr 08, 2019 1:04 am
by greenamex2
Didn't know you could do that...thanks, my workbook is looking really good!...every day is a school day!
Re: Layout Editor
Mon Apr 08, 2019 10:50 am
Hi Ray,
Was this a Notes window in the Knock worksheet?
If you double click on the title bar of the maximised window does it resize back to the minimised size?
You should also be able to grab an edge of the window and resize the window down.
This occurs as the notes windows are handled differently in Tune and the expectation was that once they are in place then they would not need to be maximised, and that any resizing done to them would be a permanent change to the size.
