M1 GPRP - Push to pass
Hey is there a good way to setup Push to pass adding little extra boost during some seconds?
The official support forum for MoTeC products
https://forum.motec.com.au/
David Ferguson wrote:It seems like the easiest modification to the GPR / GPRP might be adding an Auxiliary Time Boost Limit to the list of Auxiliary Time compensations. Or perhaps Aux Time should drive an output, then you could wire back as a Driver Engine Boost Limit switch.
SDean wrote:Hi,
It has been added into the feature request list for consideration.
