Dyno
Dyno
Postby gtihk on Tue Mar 05, 2019 7:01 pm
Anyone using a Dyno Dynamics which can connect to a M1 ECU?
gtihk
Re: Dyno
Postby David Ferguson on Wed Mar 06, 2019 1:31 am
I’ve been using the CAN interface with the M1 to work with my Dynapack’s new CAN interface. This is a really worthwhile addition, particularly if you can receive the torque from the dyno and have it available in M1 Tune, Really helps setting up Ignition timing and VVT much easier with everything on one screen.
I also sent Cam position and ignition timing to the dyno so the logged runs can indicate what was used to produce the results.
Re: Dyno
Postby Stephen Dean on Wed Mar 06, 2019 8:34 am
NIce to hear that the CAN interface into the DynaPAck Works David, I have been looking at getting it for my dyno but I wanted to hear how it worked first.
Re: Dyno
Postby gtihk on Wed Mar 06, 2019 7:22 pm
Good top know Dynapack has a CAN interface that works.
But, I was asking about Dyno Dynamics Dyno.
Anyone has experience to share?
Stephen, they are not too far from where MoTec is.
Some of you must know them?
gtihk
