Tune maximise
Tune maximise
Postby GWRMOTORSPORT on Mon Feb 04, 2019 11:04 am
Just thought I'd check in case its my PC. When I double click or press F6 the panels in tune all seem to expand
and collapse fine except the NOTES one, they maximise then freeze that worksheet, I can't collapse back with
double click or F6, only option was to go into layout editor and delete. Haven't check all NOTES as didn't want to have to delete them all, V1.4.0.200
Steve
GWR Motorsport
GWRMOTORSPORT
Re: Tune maximise
Postby Stephen Dean on Mon Feb 04, 2019 1:41 pm
Hi Steve,
I have been able to replicate this issue and I have reported it to the developers to investigate.
In the mean time, closing and reopening the Package (painful I know) will reset the notes window back to default.
Re: Tune maximise
Postby Stephen Dean on Mon Feb 04, 2019 2:18 pm
Hi Steve,
Further testing shows that you can recover back without having to close and reopen the Package.
It is possible to still manually resize the window even if it doesn't respond to any of the Maximise commands. If you grab the window in the corner you can drag and drop it back to the correct size.
