M150 not allowing Engine to rev past 4000 rpm
I am running a 2006 Yamaha R6 with the GPR-P package.I calibrated most of the cranking ignition and fuel trim tables to get the engine to start with some consistency. However, no matter my throttle input the engine will not Rev past 4000 rpm.
I have double checked the engine rev limit state and it says the current limiter is coolant temp which is set at 14600 rpm. I've checked the throttle body to make sure it is being actuated properly and I can see in the data that the Map Pressure rises almost to atm when the throttle in increased. Through all of this though the rpm stays at a constant 4000 rpm. I checked the timing using the Timing test mode with a timing light on the trigger wheel and everything checks out. The measured Lambda values are remaining stable at around stoich not matter the change in MAP or Throttle input.
It seems like there is some limiter in place that I can not seem to find can anyone help with this?
