Converting M150 Package to M190 Package
Sun Nov 12, 2017 9:16 am
by Herrubermensch
I have an M150 package that I want to run on an M190. I tried comparing in M1 Tune, and that does not work. Am I relegated to inputting the data manually from M150 package into M190 package or is there some way to migrate data between non-matching firmware?
--Peter
Re: Converting M150 Package to M190 Package
Mon Nov 13, 2017 9:41 am
by adrian
You should be able to open both the M150 and M190 packages and migrate data no problem.
When you say it doesn't work, what exactly is happening? What packages are you using?
Mon Nov 13, 2017 9:55 am
by Herrubermensch
None of the data migrates.
Trying to migrate data from a GPR for M150 to a customized GPR for M190. When I try to do so, none of the data shows up. All null.
--Peter
Mon Nov 13, 2017 9:58 am
by Herrubermensch
Low and behold, it worked. I must have done it ten times, and the data never migrated. This time, it did.
--Peter
Sun Nov 19, 2017 10:00 pm
by PEI330Ci
What's going on here?
Mon Nov 20, 2017 12:06 pm
by Herrubermensch
PEI330Ci wrote:What's going on here?
LOL. Just making good use of my M190 on the E46 M3 racecar!
--Peter
