EGT sensor for Time Graph
I have replaced an M4 with an M130GPA and think that I may have made a mistake with the EGT sensor set up.
The M4 used a K type thermocouple with a Motec amplifier with the signal being connected to "AUX T".
For the M130, I connected the signal to Analogue temp 2, the sensor ground to Sensor 0V (A) and the amplifier power to Sensor 6.3v.
The probe is on cyl 2 pipe so I used the channel Exhaust Temperature Cylinder 2 Resource. For calibration I used MoTec TCA.1.0 and for Voltage Reference "absolute".
I also do not know how to generate a "translation" channel which could be dragged to the "Time Graph" and struggle with this methodology for other resources (such as ambient air pressure) too.
Thanks for the help.
Rupert
Rupert
