Idle Control
Re: Idle Control
Postby Stephen Dean on Wed Mar 02, 2022 12:29 pm
You will need to expose the settings to be able to set the Offset and Scale for the Throttle Servo.
Re: Idle Control
Postby ryansoltau on Wed Mar 02, 2022 12:36 pm
Thank You
ryansoltau
Re: Idle Control
Postby ryansoltau on Fri Mar 04, 2022 9:04 am
Hi we are having issues smoothly accelerating out of idle control as well as coming back into idle control. Is there specific parameters to control the response of the pedal that could help this acceleration become more smooth. Also when we are above the idle control range we are having a hard time getting the engine to come back into idle control without the engine dying.
Any help would be much appreciated.
ryansoltau
Re: Idle Control
Postby David Ferguson on Fri Mar 04, 2022 9:41 am
There are too many parameters (and many interact with each other) for us to keep guessing as to what you may need to change.
If you want help. Export your current package, and upload the archive file so we can look at it.
A .ld logged data file showing the problem is also helpful. If you have level 2 logging and can add channels related to idle control, that is the best, but sometimes logging from a MoTeC dash with additional channels sent to the dash but not in the diagnostic logging is adequate.
Re: Idle Control
Postby ryansoltau on Fri Mar 04, 2022 10:55 am
Thank you we will set up idle control channels and do some runs to simulate our issues tonight and get those sent to you guys.
ryansoltau
