M1 Tune 1.5 feedback
Postby greenamex2 on Thu Nov 14, 2024 9:01 am
Not used in anger but ...
Like the new look and features.
Really infuriating seemingly not being able to add to "favourites".
The touchscreen additions are exactly what I envisioned when I mentioned tablet compatibility some years ago. Just add the keypad and extend to other inputs (my car has a touchscreen and PC built in so vested interested).
Would love the option to select the start up a specified "workspace after connecting to the ECU, for instance Monitor -> Dash. Again, vested interest with the in car PC and 12" touch screen monitor.
greenamex2
Re: M1 Tune 1.5 feedback
Postby NathanB on Thu Nov 14, 2024 9:26 am
Adjust editing.png (41.94 KiB) Viewed 20542 times
In options you need to turn on Enable adjust group editing.
Then you will have the settings gear appear
Adjust group editing 2.png (21.39 KiB) Viewed 20542 times
At the bottom of this screen, you can change your favourites.
Adjust group editing 3.png (15.01 KiB) Viewed 20542 times
This was covered on page 32 of the user guide that was also provided for download.
Postby greenamex2 on Thu Nov 14, 2024 6:59 pm
Awesome, will have a play tonight.
greenamex2
Postby greenamex2 on Fri Nov 15, 2024 8:56 am
That is pretty neat, especially for those of on the Multi Throttle Body tuning method using the Inlet Manifold Pressure Estimate Main table I can never remember about!
greenamex2
Postby Thezedhed on Fri Nov 22, 2024 1:38 am
I've only just started using Motec M1 tune (1.4) and so just getting to grips with resource assigning.
Loving the new look and pin out pictorial, very handy.
Is there a way to edit the I/O resources names that you pick from or add a note so I know what they actually are?
For example I'm wanting an I/O's for an Accusump pressure sensor and solenoid but can't find anything meaningful.
I have an excel spreadsheet listing what they are but didn't want to be complicating things if there was a better way.
Thanks in advance
Thezedhed
Postby SOReilly on Fri Nov 22, 2024 8:36 am
Thezedhed wrote:I've only just started using Motec M1 tune (1.4) and so just getting to grips with resource assigning.
Thanks in advance
M1 Tune doesn't have any name aliasing. If you are logging a channel and want the name to appear differently for analysis i2 allows you to alias a channel
SOReilly
Postby Thezedhed on Fri Nov 22, 2024 9:03 am
Thanks for the reply SOReilly,
At least I know I'm not missing something or doing it wrong :D
Thezedhed
Postby Suprafied on Mon Sep 08, 2025 3:05 am
Is there an option to hide all of the dials that are available to adjust functions?
Suprafied
Postby SOReilly on Mon Sep 08, 2025 4:33 pm
Hi Suprafied,
In the top menu bar open Tools>Options, on the applications tab at the bottom you can disable all the touch controls.
SOReilly
