Implementing Anti-Lag System using the M150
Postby XXY on Tue Jul 02, 2024 1:38 am
Hello, I would like to inquire about how to set up a Anti-Lag System in the M150. I recently purchased a turbo and am currently testing it through the M150.
Much appreciated.
XXY
Re: Implementing Anti-Lag System using the M150
Postby Stephen Dean on Tue Jul 02, 2024 11:17 am
Anti-lag is an area of tuning that you will likely not get a lot of help with from online sources. There is a lot of variables involved in getting an anti lag system working correctly, and what works for one engine/driver combination will not work with another.
Do you have the GPR Firmware in your M1? this is the minimum needed to have the Anti-lag functionality in the M1.
Postby XXY on Tue Jul 02, 2024 1:10 pm
Yes,I have the GPR Firmware in my M1,I can use it to control my engine normally.
XXY
