Hello, I have an m130. I want to check the plausibility between the throttle body position sensor and the tps to send a command to the PDM15 in order to disconnect power to the throttle body. How can I do this?
Thank you very much!!
greenamex2 wrote:When you say tps, is that not the same as throttle body position sensor? Or do you mean tps = Throttle Pedal Sensor?
Stephen Dean wrote:The M1 should be the only device controlling the DBW throttle, with the PDM supplying power to the M1. What are you trying to do?
Thunder wrote:greenamex2 wrote:When you say tps, is that not the same as throttle body position sensor? Or do you mean tps = Throttle Pedal Sensor?
Excuse the confusion. TPS=throttle pedal sensor.Stephen Dean wrote:The M1 should be the only device controlling the DBW throttle, with the PDM supplying power to the M1. What are you trying to do?
The regulations of our competition demand "If plausibility does not occur between the values of at least two Throttle Body Position Sensors and this persists for more than 100 ms, the power to the electronic throttle must be immediately shut down. Plausibility is defined as a deviation of less than ten percentage points between the sensor."
Our throttle body has two sensors which we are tracking in the m1.
