What is the M130 Level 1 Sample Rate
Postby senordos on Fri Aug 14, 2020 6:46 pm
The product material on the M130 tells me the level 2 (200hz) and level 3 (1000hz) but just says "fixed" for base level 1.
Please can you inform on the M130 level 1 sample rate? Does it differ for the GPL and GPA?
Cheers,
Christian
senordos
Re: What is the M130 Level 1 Sample Rate
Postby greenamex2 on Fri Aug 14, 2020 7:22 pm
If you go into Tune, load up a GPL/GPA map, look under the logging configuration options you can see what the logging rate is for each parameter. It does vary as things like coolant temperature don't need as much granularity as things like RPM or oil pressure.
greenamex2
Postby senordos on Sat Aug 15, 2020 3:38 am
Thanks for the tip Greenamex - I'll take a look there. Much appreciated.
senordos
