M1 GPRP - Push to pass
Postby karel021 on Sun Apr 07, 2019 9:43 am
Hey is there a good way to setup Push to pass adding little extra boost during some seconds?
karel021
Re: M1 GPRP - Push to pass
Postby karel021 on Mon Apr 08, 2019 1:07 am
i reckon its gonna be this ? or could it be used like this?
only downside is that he needs to hold the button, i would like to have it timed.
[img]
[/img]
karel021
Postby Stephen Dean on Mon Apr 08, 2019 12:54 pm
In the M1 the easiest way to do this is to setup the Driver Switch as a Latching switch, this allows for a momentary press button to be used to toggle a higher boost limit on and off. If you also have a MoTeC Dash in the vehicle, then you could use the functions in this for more control.
Postby karel021 on Wed Apr 10, 2019 8:38 am
Ah yeah i thought of that to :)
but i want to make it easier for the customer, pushing it on and off would make for more distraction :/
Its a 2015 Porsche 991 carrera cup car that iv just switched form bosch ecu to a m150
it still ha the cosworth/porsche ips and Icd, the IPS we are going to keep but i think the icd will need to be changed.
however you guys should consider put this in the gpr and gprp for the future :)
karel021
Postby David Ferguson on Wed Apr 10, 2019 8:58 am
It seems like the easiest modification to the GPR / GPRP might be adding an Auxiliary Time Boost Limit to the list of Auxiliary Time compensations. Or perhaps Aux Time should drive an output, then you could wire back as a Driver Engine Boost Limit switch.
Postby Stephen Dean on Wed Apr 10, 2019 10:30 am
It has been added into the feature request list for consideration.
Postby karel021 on Fri Apr 12, 2019 5:03 pm
David Ferguson wrote:It seems like the easiest modification to the GPR / GPRP might be adding an Auxiliary Time Boost Limit to the list of Auxiliary Time compensations. Or perhaps Aux Time should drive an output, then you could wire back as a Driver Engine Boost Limit switch.
Yeah thats true it could be done with this, not the best way but it would go for sure :)
I will play around with it as the cup car needs to be finished soon.
SDean wrote:Hi,
This sounds good :) hope you will implement it
karel021
Postby MalcolmG on Sat Apr 13, 2019 12:41 pm
If it's very important then you could consider using M1 build to add the required functionality. I have added a feature in one of my packages that essentially does what you want - it increases the boost aim for a programmable period of time, and then after this there is a programmable stand-down period before the system can be used again. It's not super-simple to do because of the way the Motec Boost Control system works, but any good M1 developer should be able to do it.
MalcolmG
