Setting base timing offset
Discussion and support for Nissan R35 GT-R Plug-In ECU Kit
Postby Mickwitchy on Mon Jun 30, 2025 8:22 pm
Hi there,
Has anyone here had any experience with putting a timing light on the r35? I can see a couple of notches on the crank pulley, but I don't see a corresponding mark on the engine to assess timing offset accuracy. What do people normally do with the R35 to set this up?
Cheers,
Mickwitchy
Re: Setting base timing offset
Postby David Ferguson on Wed Jul 02, 2025 10:47 pm
The factory workshop manual normally has that information. Of course there are many modern engine with no timing marks -- I usually end up dead-stopping the engine and making my own marks to set the correct offset.
Here is a webinar from HP Academy that shows how to find the TDC of the engine.
https://www.hpacademy.com/previous-webi ... ad-center/
Return to Nissan R35 GT-R Plug-In ECU Kit
