Idle-control in a 2-Group 3D ECU
Hi all,
I'm running a Volvo OHC 4cyl using a 2-Group 3D box, which I believe has been flashed with the most recent firmware that was written (V4.2 Revision E ... I think). I've got some odd-control behaviour, and was looking for any thoughts or suggestions.
Firstly, I have had advice from MoTeC tech support (Andrew?), who sensibly suggested it'd be best to just tune the car to want to idle at ~950rpm using fuel & spark. Then use idle-control as a backup to that. I've only just added an O2 logger & rebuilt the head, but hopefully soon I'll be able to tune it properly.
Anyhoo, it has always displayed some odd behaviour when idle-control is working. If you let it drop through about 1500rpm, then it settles itself quite happily, regardless of how quickly it's dropped or what temp it's at or what sort of load it's just been under. But if you touch the throttle when it's under about 1500rpm, then it starts to hunt & starts to act like it's badly underdamped (if I remember my control-theory geektalk properly). Changing the gain & ?damping? factors doesn't seem to have any effect at all; and I'm using an IAC valve from a 4.1L EEC4 Falcon (potentially too big for a 2.3L engine). It's something that's fairly easy to get around by blipping the throttle so it goes over 1500rpm & then leaving it alone; but the car would be so much nicer to drive without the need to do that.
I've heard rumour that idle-control in these (admittedly ancient) ECU's wasn't the best ... guess I was just wondering if anyone else had experienced the same, and/or worked out a way 'round it?
