M4 Gear Detection
M4 Gear Detection
Postby Taylor on Tue Jun 16, 2009 3:14 pm
I have my VSS(digital signal) to DIG 1input and selected as Speed Measure.
I have Gear Sensor Source set to Dig 1.
I have all the correct gear ratios, final drive(via factory specs), teeth count and calibrations set, and matchs my speedo on the dash +/-1 mph.
When looking at the sensor view(V) It reads "speed", but does not display which gear I am currently in. It reads 0 as my gear selected.
Is this only available through advanced functions?
Taylor
Re: M4 Gear Detection
Postby RossB on Fri Jul 10, 2009 4:51 pm
It sounds like you have done everything. Can you post your configuration and let me know your tyre circumference?
Return to Old ECUs
