M8 options
Sat Jun 29, 2024 5:00 pm
by w460
Hi to all!
Please may anyone help me to define.
I hve successfully connected to my m8 ecu and discovered that it has : Logging 512k, PRO logging and Lambda.
1.What is the difference between logging and PRO logging?
2. I want to buy C1212 dash. Will it work or Telemery option is needed to use them together?
My best regards!
Re: M8 options
Sat Jun 29, 2024 6:23 pm
by greenamex2
Pro logging allows you to use i2 Pro rather than i2 standard to analyse the data. Big bonus!
Yes a C1212 can read data from an M8. If you want to look at what is available download c1212 dash manager and have a play.
Re: M8 options
Mon Jul 01, 2024 4:08 pm
by SOReilly
Yes the C1212 can receive data from the M8 however they are not natively RS232. The M8 comms are TTL.
Back in the day this would require a CIM to shift the voltage levels to suit the RS232 interface of the dash. the CIM are no longer available.
Re: M8 options
Mon Jul 01, 2024 6:43 pm
by greenamex2
SOReilly wrote:Yes the C1212 can receive data from the M8 however they are not natively RS232. The M8 comms are TTL.
So would a simple MAX232 based TTL to RS232 be OK or did the CIM do something with protocol as well?
Re: M8 options
Tue Jul 02, 2024 11:19 am
To be honest, no idea. I haven't used one of those devices to attempt to communicate with an early gold box ECU, so I do not know if it would work, and we do not have any staff working here anymore that would know enough about both systems to be able to give a definitive answer.
