Page 1 of 2
Zero the TPS at idle
Mon Jul 22, 2019 10:35 am
by Edszx14
My throttle position sensor shows 1.4% when the engine is idling. How can I zero the throttle position sensor to read 0% at idle. Thanks
Re: Zero the TPS at idle
Tue Jul 23, 2019 12:02 pm
by SprinterTRD
Which ECU do you have?
Tue Jul 23, 2019 1:52 pm
by Edszx14
I have the M130. Thanks
Tue Jul 23, 2019 3:39 pm
When connected to the M130 using M1 Tune, go to the Initial Setup 2 workbook, and then the Throttle Pedal worksheet.
With you foot off of the pedal, select Throttle Pedal Main Offset and press the Q key on your keyboard. This will read the current value on the throttle and apply it to the calibration. Save the changes to force the changes to the M1.
Tue Jul 23, 2019 11:01 pm
by Edszx14
Awesome. I will give that a try. Thanks for your help.
Wed Jul 24, 2019 4:49 am
by Edszx14
Hello Mr.Dean. On my M130 I do not have the Throttle Pedal Main Offset available to me. My only selection is called " Driver Throttle Pedal translation Switch". I selected this and then pressed the "Q" on my keyboard but that didn't solve the issue. Any help you can provide it greatly appreciated. Thanks
Wed Jul 24, 2019 10:55 am
What is the Firmware that you are running in the M1? If you send me the serial number I can look this up as well.
The Driver Throttle Pedal Translation Switch is a switch that allows for multiple throttle pedal translation tables to be used, this lets the driver tune the relationship between the Throttle Pedal and Throttle Servo (on a DBW system) to be varied in the vehicle by swapping between different maps.
Wed Jul 24, 2019 1:39 pm
by Edszx14
The serial number is 4861
Firmware - Motorcycle drag race
Firmware version - 01.01.0037
Thanks,
Eddie
Wed Jul 24, 2019 3:00 pm
Hi Eddie,
As the Motorcycle Drag Race Package is a custom Package built on an older base than our current Packages, there are some differences in the functionality compared to what I described earlier.
The Parameter that you need to find is
Throttle Position Sensor Offset, with the throttle control lever in its resting position, select this Parameter and then press the
Q key to set the 0% value on the throttle.
- Motorcycle Drag TPS.PNG (9.91 KiB) Viewed 28064 times
Wed Jul 24, 2019 10:18 pm
by Edszx14
Hello Mr.Dean,
Thanks for your help. I will give that a try and let you know how it works.
Eddie
