Saving 2-Group log data in another format?
Postby Forg on Mon Feb 09, 2009 9:43 pm
As I don't have a way of getting lambda into the ancient 2-Group, I had been planning on uploading the WinLog results from the wideband 02 sensor/controller thingy and lining it up against the MoTeC log in order to analyse my tune & tweak it.
Problem is ... I can't see how to extract the logged data from the MoTeC. I can view it using the analyser, but can't see how to extract it into another format.
Is there a way to do it?
Forg
Re: Saving 2-Group log data in another format?
Postby SprinterTRD on Tue Feb 10, 2009 8:14 am
The only way to view 2 group data is with the inbuilt interpret software, there is no way to export the data into another format.
Postby Forg on Tue Feb 10, 2009 1:40 pm
I presume that's the official line, it being so old & MoTeC obviously not wanting to waste time & money on officially supporting it to that level ... however, it wouldn't be possible to get a spec for what's actually in the file, would it?
It just seems silly to have this data just sitting in that file & to be so hobbled in ability to use it. :)
Forg
Postby Forg on Tue Feb 24, 2009 10:34 pm
In case this is of help to others; it turned out all that was needed was to go into the VIEW (View & Print) application, select a log-file, and Alt+F4 to "print to file".
Generates a text-file holding the chosen fields, fields separated by spaces & CR/LF at the end of each line.
Forg
Return to Old ECUs
