2 group cold start
i am struggling to get my race 4AG to start properly from cold
a quick squirt of aero-start and its fabulous, but left to its own devices it simply will not start from cold, unless its got 100% fresh plugs. this has been progressively getting worse over a period of some years
once its hot and been used in a race, restarting is still no problem, even on 'cold" grade 7 (or colder) plugs
I have tried changing the cold enrichment from 30 to 90 units and it makes absolutely no difference
i have also tried various adjustments to cranking enrichment with no change
the ignition side has been comprehensively tested
is there anyway i can check if the cold start function is even working or the ECU has a fault?
thanks
thanks
