2 group cold start
2 group cold start
Postby terryo on Tue Apr 25, 2017 11:06 pm
i am struggling to get my race 4AG to start properly from cold
a quick squirt of aero-start and its fabulous, but left to its own devices it simply will not start from cold, unless its got 100% fresh plugs. this has been progressively getting worse over a period of some years
once its hot and been used in a race, restarting is still no problem, even on 'cold" grade 7 (or colder) plugs
I have tried changing the cold enrichment from 30 to 90 units and it makes absolutely no difference
i have also tried various adjustments to cranking enrichment with no change
the ignition side has been comprehensively tested
is there anyway i can check if the cold start function is even working or the ECU has a fault?
thanks
terryo
Re: 2 group cold start
Postby CamB on Wed Apr 26, 2017 10:59 am
Not sure if its helpful but mine (a 3.2 litre Porsche with individual TBs and a moderate cam) has:
- warm up - 92.0
- post start - 120
- cranking - 162
- decay - 10
Are you sure the ECT sensor is working (so it knows to enrich it)?
CamB
Postby terryo on Thu Apr 27, 2017 12:11 am
thanks for those values. i'll compare.
yes, the temp sender appear to be working. both air and water temps are 22C before i start, so very close to workshop ambient. once warmed up water temp is 85-100C, so seemingly sensible
terryo
Return to Old ECUs
