Can M8 Be used with LS1 with stock crank and cam sensors?
Postby Turbofreak on Sun Jun 22, 2014 2:17 pm
Trying to see if I can use the stock sensors in an LS1 engine with my M8 ECU.
Thanks in advance!
Turbofreak
Re: Can M8 Be used with LS1 with stock crank and cam sensors
Postby stevieturbo on Mon Jun 23, 2014 5:02 am
I would say yes.
However, whether the M8 is able to decode that terrible 24x crank wheel is another matter.
But the actual sensors should be fine.
Postby SprinterTRD on Mon Jun 23, 2014 2:32 pm
Just use multy tooth mode with failling edge on the crank. This edge is evenly spaced.
You may however suffer at high RPM with the sync crossing over the crank edge due to cam belt streach and causing a missfire
Postby stevieturbo on Tue Jun 24, 2014 9:55 am
SprinterTRD wrote:Just use multy tooth mode with failling edge on the crank. This edge is evenly spaced.
LS1 uses a weird 24x trigger, the teeth are not evenly spaced.
LS1 is an old pushrod V8, there is no cambelt.
Some visuals and info on the crank trigger. Cam trigger is easy though
http://www.vems.hu/wiki/index.php?page= ... wentyFourX
be as handy just to stick a 36-1 onto it.
Postby AdamW on Tue Jun 24, 2014 11:52 am
stevieturbo wrote:LS1 uses a weird 24x trigger, the teeth are not evenly spaced.
Sprinter TRD specifically said Falling edge which are in fact all evenly spaced on the LS1.
stevieturbo wrote:LS1 is an old pushrod V8, there is no cambelt.
But they still have a timing chain and distributor gears all with stretch and backlash which causes the same problem. In multi tooth mode if your sync position moves too close or especially crosses over the ref trigger edge you can get trigger errors.
Motorsport Electronics Ltd.
AdamW
Postby stevieturbo on Wed Jun 25, 2014 2:42 am
Didnt realise that. I just see the 24x as the trigger from hell. Even with the OEM ecu, it seems to cause many problems especially at high rpm.
Wheels dont run true, the wheel splits apart etc. They just seem to be very poor.
Postby Turbofreak on Mon Jun 30, 2014 1:37 pm
Got an Answer from Simon at Motec West the other day on this one.
He is a super great guy and I sure appreciate his kindness and expertise!
He said the M8 never has had a 24 tooth setting available for the terrible signals it produces.
He also said He could upgrade it to an M8-High Speed for a minimal fee and it will work with the new 58X Gen IV LS trigger wheels, so that is useful!
Turbofreak
Postby stevieturbo on Tue Jul 01, 2014 7:39 am
Yes, but if you have an engine with the 24x wheel, it's a crankshaft out job to swap the wheel to 58x.
It would be a lot easier all round just to mount a new wheel, 36-1 or otherwise on the crank pulley.
Postby Holmz on Tue Jul 01, 2014 7:44 am
Turbofreak wrote:...
Do you have a capture of that signal?
Or what is the nature making it terrible?
Postby AdamW on Tue Jul 01, 2014 10:21 am
Turbofreak wrote:Got an Answer from Simon at Motec West the other day on this one.
I don't see why mode 11-14 wont work - the max recommended teeth is 16 for this mode but that is only because it gives you a small "window" where the sync edge must occur.
You could also just cut some teeth off the original wheel to make it into a 4, 8 or 12 tooth wheel.
Holmz wrote:Do you have a capture of that signal?
There is some captures shown on the link that Stevieturbo posted earlier in this thread.
AdamW
Return to Old ECUs
