Gp2 ecu parts?
PostPosted: Wed Jun 04, 2014 10:26 pm
by 82leone
Hi I aquired this ecu with 3 engines I bought and I am keen to use it. The problem I have is the plug and wiring went with the shell of the car. If anyone could share some info on where I could get a plug and harness I would be greatly appreciative. I have found the pin out sheet and instruction booklet on the site but have not come across anymore info thanks in advance Shane
Re: Gp2 ecu parts?
PostPosted: Thu Jun 05, 2014 9:34 am
by SprinterTRD
The Connector is the same as the M4/M4-8 and is available from MoTeC Dealers.
Have you got the hand calibrator as well? I notice that it is version 2.1 software which cannot be used with the PC software.
It is also setup to only use a Hall crank sensor
Re: Gp2 ecu parts?
PostPosted: Thu Jun 05, 2014 11:38 pm
by 82leone
No hand controller but it goes with the engines supplied all the sensors etc are all still with the motors. So hopping I can just wire it back up and it will work. Thanks for the reply.
