- M8 trigger config.jpg (7.48 KiB) Viewed 21196 times
I have a very noisy rpm signal on a car fitted with this trigger wheel and want to verify the setup. With a timing light hooked up, I am seeing the timing jump around as much as ten degrees, and while tuning, the rpm is very "jumpy", this can be seen in the datalogs as well. There is a slight amount of slop between the wheel and the distributor shaft, which may be an issue, however I want to verify that the configuration is correct for this trigger wheel. Also, the wheel looks like the "M PCHOP CCW" , but I don't see any markings on it to verify. I see that there is a M PCHOP CW and M PCHOP CCW, one for clockwise and other other for counterclockwise rotation. Can someone identify which one I have ? Any help or suggestions appreciated, I would like to avoid having to put a separate cam and crank trigger on this car if I can.
