ID Old ECU
ID Old ECU
Postby Rossco on Fri Oct 24, 2008 9:52 pm
G day guys i was just wondering if i could get some help identifying an older model motec, was given to me by a mate for my fun day track car im playing with, it came with the ECU, loom and nothing more so i was wondering if parts are still available for me to purchase and software available for download, ive included some pics and your help would be fantastic! :)
Serial: 9301011, p/n CEM-2D, EPS 4.0 E2 are the only numbers on the outside of the case and it has a rectangular 36 pin connector
Loom Plug.JPG (426.41 KiB) Viewed 17139 times
Rossco
Re: ID Old ECU
Postby NathanS on Sat Oct 25, 2008 6:04 am
Hopefully one of the older MoTeC guys :D will be able to confirm this but as far as I know this is one of the 2 Group ECUs which only has 2 Injector drivers and 1 Ignition driver but no memory. This requires either a hand calibrator to map or a modem to connect it to your PC, were you given either of these or does your mate have them as we no longer sell them and I don't think I've ever physically seen one.
You can download the software from our Old Releases webpage http://www.motec.com.au/software/oldreleases/, I have attached the only copy of the manual that I could find for you.
2 Group Manual.zip
(2.3 MiB) Downloaded 1774 times
NathanS
Re: ID Old ECU
Postby Rossco on Sat Oct 25, 2008 7:07 pm
nah only have the main ECU and loom as a said sadly, not looking good aye!
Rossco
Return to Old ECUs
