M8 - old software release request
PostPosted: Thu Feb 02, 2012 2:59 am
by ale.agos
Hello everybody,
as in last posts I'm working with the goal to fit an old M8 unit ECU and the Judd Engine who was run with it on a Lola B99/50 F3000 car.
At now I've been able to build up the interface cable with car's master harness and the relative part of cable who fit to the same connectors that was originally used for Zyteck ECU.
Today, for first time, I've been able to connect to the M8 ECU because I've got the right cable but I've discovered that software version on it is not compatible with software release that I'm using (I've download it here so I'm using the V6.0 of EMP software).
So, if I've well understand what was on the manual, I will need the SUU cable to upgrade the ECU software or, as wrote on the splash screen that advise me of software's version mismatching, I will need to find the right one version (V.5.4).
With the goal to short time anyone has this version of EMP?
I just need it with the goal to check that all will be ok when the ECU and sensors will be fired on car...
Thanks for attention.
Alessandro
Re: M8 - old software release request
PostPosted: Sun Feb 05, 2012 11:12 am
by Chris Wilson
Did that old release I linked you to not work Allesandro?
PostPosted: Thu Feb 09, 2012 7:52 pm
by ale.agos
Yes Chris, was OK! I've found the right one software release on the Motec web site under old software section...
Thanks a lot for your infinite assistence!
