GP2 ECU
PostPosted: Tue Dec 13, 2011 3:11 pm
by Racene
Anyone help with a startup map for fuel and igition for small port Toyota 4AGE bog standard
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 3:20 pm
by MarkMc
What ECU? A 2 Group?
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 3:45 pm
by Racene
Racene wrote:Anyone help with a startup map for fuel and igition for small port Toyota 4AGE bog standard
ECU serial No 9301001 P/N CEM-2D EPS 4.0 E2
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 4:07 pm
by MarkMc
Geeez Dude,
You're really pushing it on that one, it's hard enough to find an M4 start file these days let alone a 2G. Have you modified the crank triggers at all? The 2G will only use one tooth per firing.
Do you have a transmit modem to connect it to a laptop as well? This is the only way to talk to it.
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 4:10 pm
by Racene
Sure Do
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 4:13 pm
by Racene
Crank Triggers? Removed(cut) the white wire insde disy
Re: GP2 ECU
PostPosted: Tue Dec 13, 2011 4:52 pm
by MarkMc
Your lucky day, of the two people in the building with 2G experience one of us had a 4ag map. Send me an email to mark.mccoy@motec.com.au
