Hello everybody,
one of mine costumer asked me to make a new loom with the goal to interface its M8 ECU with a Judd V8 3500cc engine (ex. Lotus F1).
Actually he has the original loom but it is in a bad condition so he would like to replace it with a new one that will fit on the car's chassis / components.
Usually I don't build engine's loom because my work is focalize on data acquisition so I've build loom for that purpose in the past but I would like to do that for this costumer.
On Motec web site I've been able to find a scheme who explain what are components that need to be connect to the ECU and give info on connectors pin-out so that could be a good start for my job. What I haven't found on web site is a detailed scheme of Ignition System ( the scheme that I have refer to another drawings ) so could someone of you provide me this scheme? About connectors on ECU I will need to re-use the oldest two or I will be able to find them new? Someone of you know their part number / manufacturer ? About ECU I've seen that it has an old software write to work with DOS O.S. called E.M.P. software so any chance to use a new one software that could be run on system without DOS O.S.?
Thanks to all for collaboration.
Alessandro
