M8 Connection Problems
Postby Olivert on Sun Sep 28, 2008 2:28 am
I am having a bit of difficulty connecting to an M8 Mil ECU. I am using a Thinkpad T43 and am connecting using all the correct leads. I think my problem lies in the fact that I do not have a 9 pin serial port on this laptop. I have purchased an adaptor to convert from the 9-pin serial to a USB. Windows XP recognises the connection to the ECU as a Mouse (and goes a bit haywire!) But on starting the EMP I am unable to connect to the ECU. Can anyone advise what I might be doing wrong?
Thanks,
Oliver
Olivert
Re: M8 Connection Problems
Postby SprinterTRD on Mon Sep 29, 2008 9:42 am
Boot the laptop up before connecting the PCI cable to the M8.
Make sure infared ports are turned off in the laptop bios as they get assigned to com1
Check that the serial port is com1 if not set this in the laptops bios.
Postby Olivert on Sat Oct 04, 2008 4:56 am
Thank you very much - that is precisely what it was. It was a USB device and when plugged in it was assigned COM3 - now assigned to COM1 and I can connect and download.
Cheers,
Oliver
Olivert
Postby beefcake on Wed May 06, 2009 9:10 pm
:lol: sounds like the same drama i have now,
Ive searched this website to help me and this one soounds the closest i got, my com port is either com11 or com 12, how the f##k do i assign my lappy to read com 1 for the usb to serial adapter, i cant connect my m2r too my lappy to set it up :?
PB of 10.01@138 mph
http://www.youtube.com/watch?v=w2k_idn71ro
beefcake
Postby beefcake on Fri May 08, 2009 12:13 am
no worries i got a mate too re assign my usb port to read number 2, and then the motec found it, thanks
PB of 10.01@138 mph
beefcake
Return to Old ECUs
Users browsing this forum: Google [Bot] and 1 guest
