M8 and VT dual hall effect distributor
Postby m100 on Fri Jul 22, 2011 2:33 pm
M8 ver 6.05f software REF/SYNC modes 1 to 4. F1 help says active SYNC edge should occur midway between active REF edges.
How critical is this?
On VT distributor SYNC rise is approximately coincident with REF fall which I suspect eliminates that mode as a possibility.
Remaining 3 SYNC/REF modes put chosen active SYNC edge at various positions between chosen active REF edges but not midway between.
Intend to use DUAL edge timing.
Is this acceptable?
m100
Re: M8 and VT dual hall effect distributor
Postby MarkMc on Mon Nov 07, 2011 5:14 pm
"mid-way" reallistically means "not at the same time as a ref", we have used the VT distributors on many engines over the years, it will be fine.
Postby m100 on Wed May 01, 2013 5:27 pm
A belated thanks for the reply, all works.
m100
Return to Old ECUs
