Not Displaying Properly
Re: Not Displaying Properly
Postby kotaro-jpn on Mon Oct 07, 2024 10:56 pm
After that I tried various display drivers but there was no improvement.
The results were the same even when I used the standard Windows driver.
What I'm wondering is that when I use my PC with multiple monitors
the PC works with multiple monitors on the adjustment screen and setup screen
but when I press "G" on the adjustment screen to display a graph it no longer works as a multi-monitor and only the laptop screen is active and there is no signal input to the sub-display.
It is certain that some conditions change only when I press "G" to display the graph screen.
kotaro-jpn
Postby Stephen Dean on Tue Oct 08, 2024 3:26 pm
The problem is that you are using a 8bit program, in a 16bit subsystem on a 32bit operating system. There is a link somewhere along the chain between the program and the video driver that is not working correctly thus the graphics not displaying correctly.
Postby kotaro-jpn on Mon Oct 14, 2024 4:18 am
Thanks for the tips. I'll give it a try.
kotaro-jpn
Return to Old ECUs
