M8 Upgrade
M8 Upgrade
Postby Olivert on Fri Sep 10, 2010 1:05 am
The Manual clearly states that the Advanced Tuning Option is already enabled in the M8 ECU. But my Mil Spec M8 doesn't have any logging or traction enabled. How do I go about solving this?...
Thanks,
Oliver
Olivert
Re: M8 Upgrade
Postby MarkMc on Fri Sep 10, 2010 1:35 pm
Hi Oliver,
What is the serial number of your ECU? Also, when/where did you buy it?
Re: M8 Upgrade
Postby Olivert on Fri Sep 10, 2010 10:03 pm
sticker on the end says: 9802 Serial 651 EPS C7.
I purchased it second-hand. Original owner was based in Northern Ireland.
Thanks,
Oliver
Olivert
Re: M8 Upgrade
Postby MarkMc on Fri Sep 10, 2010 10:10 pm
Ok Oliver,
Leave it with me, I need to check it out.
Re: M8 Upgrade
Postby MarkMc on Mon Sep 13, 2010 10:49 am
Hi Oliver,
That ECU was sold for a specific job in 1998 and was without some of the normal upgrades. Unfortunately if you want to bring it up in spec you will need to contact your local MoTeC dealer to purchase them.
Return to Old ECUs
