Is this a M48 plugin?
Postby jasaircraft on Tue Mar 09, 2010 3:12 pm
Are these pictures from an old m48 plugin ecu?
If they are, what COM cable and what software should I use for it?
the numbers seen are:
0702
also written with a black marker is 2980
which is its serial number?
sorry if questions are dumb :oops:
cheers,
jose
jasaircraft
Re: Is this a M48 plugin?
Postby jasaircraft on Wed Mar 31, 2010 7:46 am
wow severall views without response!
jasaircraft
Postby SprinterTRD on Thu Apr 01, 2010 9:51 am
Yes it is a M4-8 OEM ECU
You will need 2 cables to communicate with it. One to go from the Mitsubishi connector to a D9 connector and another which is the MoTeC PCI cable.
MoTeC Europe will be able to help with the cables.
SprinterTRD
Return to Old ECUs
