Can Someone help me identify this ECU?
Postby racedude on Mon Nov 03, 2008 10:56 am
I have the pictured ECU, may I know which software supports this product? Thanks.
Derrick.
racedude
Re: Can Someone help me identify this ECU?
Postby SprinterTRD on Wed Nov 05, 2008 11:59 am
This ECU is called a 2 group ECU. It has two injector outputs and one ignition output. It is setup to use a magnetic sensor for its crank sensor.
SprinterTRD
Postby racedude on Wed Nov 05, 2008 10:25 pm
Thanks Sprinter, which means I can use the 2 group software thats downloadable from this site?
racedude
Postby SprinterTRD on Thu Nov 06, 2008 10:52 am
You will need 2 group verson 3 software for this ECU however you will also need a transmit modem which are rare.
MoTeC has a diagram how to make a PCI cable work but this involves some electronics to make it work.
You could also use a hand calibrator to tune with.
SprinterTRD
Postby racedude on Tue Dec 09, 2008 10:52 pm
Where can I find the pinout for this ECU? I'm well versed with electronics so if you can email the details on how to build the comms cable to PC interface I'm sure I can do it. Thanks for the help.
racedude
Postby SprinterTRD on Wed Dec 10, 2008 7:59 am
The pinout is available on the .AU website
SprinterTRD
Postby RossB on Wed Dec 10, 2008 8:52 am
You will need to get a MoTeE PCI cable, the attached document describes how to make an interface for the 2 group.
DTN0007 2Group Connection with PCI.pdf
2 Group communications
(61.29 KiB) Downloaded 1992 times
RossB
Postby racedude on Thu Dec 18, 2008 12:52 pm
Thanks to all for your help, will update on my progress.
racedude
Postby dangerousdan on Sat Feb 06, 2010 9:27 am
Hi Guys, has anyone made the transmit modem supliment and did it work?
I have had two goes at making one but have not been able to get any comunication. I have sent the ECU to the local Motec guy who has been most helpful and he has been able to comunicate with it using his "real" transmit modem.
I am starting to wonder if the circuit actually works so if anyone else has made one i would be keen to hear from them.
dangerousdan
Return to Old ECUs
