Torque split adjustment
Postby rayhall on Wed Sep 25, 2024 11:10 am
This is how the stock ECU controls the torque split
In Normal driving mode the centre diff uses a 60:40 front/rear torque split, while Track mode shifts this to a 50:50 torque split, and Sport mode flips to a 30:70 torque split to lend rear-drive-style handling characteristics
I want the same with my Motec plugin.
What values do I need in the track mode table to get a 50:50 tourqe split.
Ray.
rayhall
Re: Torque split adjustment
Postby z0mgchris on Thu Dec 12, 2024 9:51 am
Ray,
looks like you need this - 61466 - TOYOTA YARIS GR 2020 DIFF LOOM
Then it's controlled via differential > rear > Clutch > control > pick the table you want. Looks like values of 5000 "Nm" will give you a 50:50? but you may need to experiment there.
Values in the base file look to be 40 rear in zero / normal, 50 in one / track and finally 70 in two / sport.
This is all theory and going by looking at the basemap (1.11.0170) with diff control.
z0mgchris
Return to M1 Plug-In ECUs
