Toyota 86 How to reflect the entire fuel amount trim
Could you please provide some information about the Toyota 86 2012 Engine Swap M1 Package?
I am using the Manual Transmission OE Injectors MY2012-2016 with the 2019 Update v7.
After starting the engine, it seems to be running rich overall. When I adjusted the AF around the idle, a value of around 80 was entered.
I tried using the Fuel Volume Trim Overall, and setting it to 50% improved the engine start and performance.
Which parameters should I adjust to reflect this change?
