GR Yaris Plugin-ECU mounting solution
Postby rayhall on Thu Aug 01, 2024 7:32 pm
How many of the orignal ECU mounting brackets are used to mount the Motec Plugin-ECU. Is there a picture or drawing showing how they attach to the Motec Yaris adaptor box.
Ray Hall.
rayhall
Re: GR Yaris Plugin-ECU mounting solution
Postby NathanB on Fri Aug 02, 2024 9:19 am
Hi Ray,
The install instructions are included in the data sheet on the USB that would have come with your ECU. Please see attached.
Yaris install instructions.pdf
(2.49 MiB) Downloaded 196 times
Return to M1 Plug-In ECUs
