GR Yaris plugin ECU switch inputs
Is the base map and adapter set up to use any existing dash or strreting wheel swithes to change settings like boost pressure, launch control, anti-lag. Or do I have to wire in a 9 position rotary switch to change the boost pressure.
Ray Hall.
Ray Hall.
