GR Yaris plugin ECU switch inputs
Postby rayhall on Thu Aug 01, 2024 1:21 pm
Is the base map and adapter set up to use any existing dash or strreting wheel swithes to change settings like boost pressure, launch control, anti-lag. Or do I have to wire in a 9 position rotary switch to change the boost pressure.
Ray Hall.
rayhall
Re: GR Yaris plugin ECU switch inputs
Postby NathanB on Thu Aug 01, 2024 2:13 pm
The drive mode switch is assigned to driver rotary switch 2.
It is not utilised for anything in the base map, but this can be used for any of the mentioned functions.
Return to M1 Plug-In ECUs
