Timing lock
Timing lock
Postby Victorgarage on Sat Feb 27, 2021 12:56 am
Do we have to check and recalibrate timing lock for set the trigger offset on 86 package v5 ?
Victorgarage
Re: Timing lock
Postby Stephen Dean on Mon Mar 01, 2021 11:37 am
The Reference Offset value should always be validated for any Package when it is first installed. If no changes are made to the engine mechanically then the same calibrated number can be used throughout further Package upgrades. If any changes are made to the engine mechanically then this value should be revalidated.
Re: Timing lock
Postby Victorgarage on Mon Mar 01, 2021 11:26 pm
SDean wrote:The Reference Offset value should always be validated for any Package when it is first installed. If no changes are made to the engine mechanically then the same calibrated number can be used throughout further Package upgrades. If any changes are made to the engine mechanically then this value should be revalidated.
The engine is all stock
But something made the TCU receive the wrong data so it wont change gear like the way it should be.
Victorgarage
Return to M1 Plug-In ECUs
