Toyota GT86 Package - Additional Sensors
Hi Folks
I have a Toyota GT86 that I'm currently building that will be running on an M150 (Level 2 logging), with an AIM Dash running off the ECU's Canbus
I'm looking to add a fuel pressure sensor for the Port Injector fuel rail,
Looking at the Motec patch harness it appears the 12 pin DTM breakout Pin F07 - "Fuel Lift Pressure" is the best input to use, however I cannot tell if this input is transmitted on the standard M1 Canbus?
I've downloaded a copy of Dash manager to look at the CANBUS template but I still can't really tell as there is an OEM high pressure fuel system and how do you distinguish between the source of all the various signals as I cannot correlate all the pinned inputs to CANBUS signals?
Cheers
Barry,
Cheers
Barry,
