Toyota GT86 CAN bus Content
Hi Folks
Sorry first post and a couple of question on my install
1) Is there a list anywhere of what CAN-bus data is active in the M1 standard template protocol for the GT86 package?
I am looking to connect a Motec M150 GT86 to an AIM MXP dash, I plan to set the dash to read the standard Motec M1 CANBus template but want to confirm if it will contain all the OEM CAN-bus data or if I need to connect a second CAN input to my dash from the chassis.
Specifically I need the following OEM data for my project:
Brake pressure
Steering Angle
Clutch switch
2) I would like to switch the standard M150 CAN template output to CAN3 output on the M150 is there any reason not to do this?
Brake pressure
Steering Angle
Clutch switch
