Flex Fuel for FRS/BRZ
Postby gkwestfrank on Wed Mar 21, 2018 12:06 pm
Hi i got a question on how to get the flexfuel to work.
i read the flexfuel guide and i also read the FRS/BRZ m150 datasheet.
the question i have is which channel can i use for the flexfuel sensor?
i read the datasheet and seem like all the udig channel have something on it.
the recommended channel in the flexfuel guide(udig7) was on IJF2 which i dont
know if i can just unplug that wire and run the flexfuel sensor vout to it.
if anyone can point me to the channel that i can use then that would be great.
it seem like i cant get a straight answer for that. thanks!
gkwestfrank
Re: Flex Fuel for FRS/BRZ
Postby Stephen Dean on Thu Mar 22, 2018 10:31 am
The Digital inputs are also able to be used as a Fuel Composition sensor input channel, and all of these are available in the standard package.
Postby gkwestfrank on Thu Mar 22, 2018 4:25 pm
Thanks Stephen , so in other word, I can run it to dig 1 to 4 in plug A and just follow the setup step in the flex fuel guide in my latest 86 package? Then I will have both E content reading plus fuel temp just like in the flex fuel guide?
gkwestfrank
Postby Stephen Dean on Thu Mar 22, 2018 4:26 pm
That is correct.
Postby gkwestfrank on Thu Mar 29, 2018 3:19 pm
thanks, it works like a champ !!
gkwestfrank
Postby gkwestfrank on Mon May 14, 2018 2:30 pm
Stephen, thanks for all the help and i got the car run well on the track. but just out of curiosity, i found the firmware help file have firmware 1 -9 and 13 listed , but what about 10 to 12 and 14 to the rest? just wonder what else i can add to the tune. thanks!
gkwestfrank
Return to M1 Plug-In ECUs
