Sync Capture not available
Postby bing on Fri May 20, 2016 2:24 pm
We having starting issue with FT86 package, we keep getting Engine Position Change diag and some Intake Cams 1/2 bad pitch.
Try to check with sync capture UDIG 1-5 but software say not available need ecu firmware update.
We had download the package yesterday, which i think its the most updated.
We want to check sync trigger make sure cam/chain timing are correct.
Thanks,
Brian
bing
Return to M1 Plug-In ECUs
