Aim solo 2 DL exporting acceleration G to M1 ecu
Hoping this was the most appropriate forum for this issue. I have an M130 ecu with motorcycle drag based firmware transmitting from the ecu to the dash over the canbus with no problems. The ecu is receiving gps data from from the dash and I added the g-meter on 0x680 to the AIM dash can output. I'm not getting any of the vehicle accel channels to read, I see blips of activity when monitoring the ecu live but it jumps back to "communications timeout".
The can receive is selected "on" to can bus 1 and the address is x0680. The dash will not accept the zero before the 680 and the ecu will not accept 0x680 without the zero after the x and before the 680.
I am obviously not sharp on canbus. Any help would be appreciated.
I took some screen shots but when I try to attach an image in this post I just get [img] and no option to select the pic.
