Syvecs to C125
Syvecs to C125
Postby bloit on Sun Apr 14, 2019 3:56 am
Hi. I’m looking for a can template to support syvecs ecu and c125 dash.
bloit
Re: Syvecs to C125
Postby stevieturbo on Mon Apr 15, 2019 7:05 am
There is some for the Life racing stuff, which would be a good place to start.
Re: Syvecs to C125
Postby Stephen Dean on Mon Apr 15, 2019 10:28 am
We had looked at doing a CAN Template for the Syvecs ECU's, but they do not appear to use a standard CAN Transmit template through their configurations so it becomes difficult for a base template to be made. They also allow for the base template to be changed quite easily.
As Stevie said, look at the Life Racing template and the cross reference the transmitted channels out of the Syvecs to see if they match up.
Re: Syvecs to C125
Postby bloit on Tue Apr 16, 2019 4:25 am
I’ll take a look at the F88 templates and go from there. Thanks for the advice.
bloit
Re: Syvecs to C125
Postby stevieturbo on Thu Apr 18, 2019 4:29 am
One of their "standard" CAN datastreams from the Life site.
https://www.liferacing.com/uploads/file ... stream.pdf
I can only assume that Motec's Life F88 templates within the dash software are based around this ?
Return to ECU to Dash Comms
