Page 1 of 2
CDL3 dash and AEM ecu
Fri Mar 16, 2012 7:29 pm
by gkwestfrank
Hi, is there any pre made serial template for AEM Ecu?
Re: CDL3 dash and AEM ecu
Sat Mar 17, 2012 4:22 pm
by gkwestfrank
i was trying it myself but couldnt figure it out, here is the serial format i got from AEM
Byte Name Units Scalar Offset Min Max Signed? Bitmask
1 Engine Speed rpm 100 0 0 25599.60938 n -
2 Engine Load kPa 1.346484 0 0 344.69476 n -
3 Throttle % 0.390625 0 0 99.99847 n -
4 Air Temp F 1.800000 32 -198.39999260.60001 y -
5 Coolant Temp F 1.800000 32 -198.39999260.60001 y -
6 ADCR11 Volts 0.019546 0 0 5.003597 n -
7 ADCR13 Volts 0.019546 0 0 5.003597 n -
8 ADCR14 Volts 0.019546 0 0 5.003597 n -
9 ADCR17 Volts 0.019546 0 0 5.003597 n -
10 ADCR18 Volts 0.019546 0 0 5.003597 n -
11 ADCR15 Volts 0.019546 0 0 5.003597 n -
12 ADCR16 Volts 0.019546 0 0 5.003597 n -
13 ADCR08 Volts 0.079360 0 0 20.31585 n -
14 O2 #1 AFR 0.035156 4.500000 4.500000 13.46484 n -
15 O2 #2 AFR 0.035156 4.500000 4.500000 13.46484 n -
16 Vehicle Speed MPH 1 0 0 255.99609 n -
17 Gear Calculated 1 0 0 255 n -
18 Error #1 1 0 0 255 n -
19 Error #2 1 0 0 255 n -
Serial Port Settings
Transmission sequence : Header byte, stream data, checksum byte
Header byte : 0x55
Baud rate : 19200
Parity : Ignore
Data size : 8 bits
Stop bits : 1
Stream size : 21
Checksum : standard data sum
Sat Mar 17, 2012 6:50 pm
by JamieA
we should have a template for you early next week. Send an email to
support@motec.com.au, and we will send it to you.
-Jamie
Sun Mar 18, 2012 4:58 am
by gkwestfrank
Nice! looking forward to it
btw, please make it also available in .cr4 too, thx Jamie
Tue Mar 20, 2012 11:22 am
by JamieA
Are you using CAN or RS232?
Our template is designed for the AEM CAN comms..
thanks
Tue Mar 20, 2012 11:55 am
by gkwestfrank
it is for serial bus, it is most commonly used on their 1st and 2nd series ecu, they both are the same format as above.
Wed Mar 21, 2012 9:19 am
by JamieA
Ok, We have already done the CAN dash template for AEM, but not RS232.
Can I possibly get the RS232 format as a file (so the formatting is a bit easier to read)
email to
jamie.augustine@motec.com.authis should be able to be done within a few days of getting the information..
thanks.
Jamie
Wed Mar 21, 2012 10:22 am
by gkwestfrank
for sure, emailing now.
thx thx
Thu Mar 22, 2012 9:49 am
by EB Turbo
Is there any literature on setting up or changing these CAN templates? Let say I want to change a channel in the template. What do I need to look for to make sure everything is set up correctly?
EB Turbo
Fri Mar 23, 2012 4:27 pm
by JamieA
I guess there isnt really.
Basically, you can select any motec CAN template, click the Edit button, and all the settings that you may need are there in the Parameters panel, or the Channels panel.
If you take an existing template (like AEM) and examine how we have implemented it, you should get the idea of how to change it to suit your applicaion.
regards,
Jamie
