Dash not reading
Re: Dash not reading
Postby SprinterTRD on Thu Feb 18, 2021 1:40 pm
Unfortunately regardless of what your tuner said its still worth checking for your own sanity!
Either the wiring is wrong or has a problem or the setup is wrong, assuming the hardware hasn't been damaged during the swap process.
If you are absolutely confident everything is correct then you need to get a oscilloscope and start measuring the waveform's from the ECU to dash.
Postby Kdog on Fri Feb 19, 2021 6:25 am
Yes, agreed. It looks like a maybe a port issue on computer. An oscilloscope isn't going to happen today. Are there any checks I can do with a multimeter?
Kdog
Postby SprinterTRD on Fri Feb 19, 2021 8:39 am
Not really, you need the scope to see if the RS232 messages are output from the ECU.
An alternative is to use a terminal emulator on the PC, connect the RS232 from the ECU to the PC and see if you see ASCII characters appearing in the terminal.
Return to ECU to Dash Comms
