Motec m150 gear position to c127 not working??
Postby Mobne on Tue Apr 19, 2022 10:41 pm
I’m using the protocol provided from motec.
I can’t get the dash to read the gear. It just shows 3 all the time.
The ecu reads it as expected. But nothing in the dash.
The channel in the c127 is just “gear”.
Any ideas?
Mobne
Re: Motec m150 gear position to c127 not working??
Postby Anthony on Tue Apr 19, 2022 11:11 pm
check the comms in the dash and that you are receiving the gear channel, its in the comms template "M1 general 0x640"
Anthony
Postby Stephen Dean on Wed Apr 20, 2022 10:48 am
What Firmware are you running in the M1?
Postby whrdnsx on Sat Dec 06, 2025 1:45 pm
Hello
I have the same problem. The solution wasn't posted.
Gear position reading fine on M150 but not the dash. Version 0.1.11.0203 Tune 1.4
Using the M1 General template. other sensors are working on the dash.
I checked on the dash config it seems that it defaults to ADR for the gear position? can't seem to change to ECU.
whrdnsx
Postby Stephen Dean on Mon Dec 08, 2025 9:27 am
Which M1 General templates are you using in the Dash?
The version the the GP Package that you are using requires the following versions to be used to work correctly.
M1_General_0x640_Version 5.1
M1_General_0x650_Version 4
M1_General_0x6A0_Version 1
Return to ECU to Dash Comms
